    Results 1 to 1 of 1
      LS1 Brakes on 67-69 camaro
      Well in my search for front adapter brackets I stumbled on BRP. They have the brackets for the drum spindles and you dont have to machine the spindle. They also have a complete kit, which is what I bought.
      It comes with the brackets, hubs machined for the rotors and the longer studs an inner and outer bearings and rear seal already installed, and all bolts required. Plus they have adapter brackets for the rear discs to go onto 10 and 12 bolt rearends nice kit and it is working well so far just mocking up the fronts. If you dont want to run around for bolts bearings studs and having spindles and hubs machined this IS the way to go. Price I thought was really reasonable. If you call ask for Phil.
      http://www.brphotrods.com/
      1967 Camaro RS, LS1, D1SC DSE Mini-Tub, TH350, 12 BOLT 3:73.
