      England
      Dakata Digital Dash
      Trying calibrate the speedo on my dash for the 67 camaro ,does anybody were the speedo trip button is and reset ,waited 2 day from dakota and no reply, need it as we have loads of speed cameras localy
      Feb 2003
      St. Louis, Missouri
      You should've received 2 buttons with your "kit". Each button has two leads on them. There is a sw1 and a sw2 on the brain. One lead goes to sw1 or 2 and the other to ground. I forget the sequence in which you need to drive/press the button, but that's how it's done.
      England
      Had the unit for 5yrs been to usa loads then find this out.
      Feb 2003
      St. Louis, Missouri
      Hate to sound like an a$$-bag, but did you download the instruction manual from DD website? Look on page 10. Any normally open switch would work. Actually, you might be able to get away with attaching a wire to the proper sw terminal and just grounding it.
      England
      So what there saying is connect a push button ,1 wire to the box and the other end to ground then press the button and do the 1 ml test run .
      Feb 2003
      St. Louis, Missouri
      That is correct.
