    Results 1 to 10 of 10
      May 2002
      Northern California
      99 C5 fuel filter/regulator
      Hi guys, ok im running into a problem with the set up in title. If I set up the lines as described in picture I get no fuel flow. But if I reverse the lines I get flow but it is at max pressure from the pump.
      In this case its 56 psi. I dead headed the pump and it ran at a consistant 55psi. Now, I know the stock spec for 1999 C5 is 55-61 and fbody it is 55-60 psi.
      My spidey senses say that the pump isn't putting out enough to operate the regulator but my instinct says the pump is fine and my problem lyes in the filter regulator cause it should pass some fuel regardless of fuel pressure. I will have a new regulator tomorrow but I wanted more input. Thanks.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Red Deer, Alberta, Canada
      That is a weird problem indeed. The pic does show hooking it up correctly.
      -Matt
      Matt
      Instagram: Cst_koon
      May 2002
      Northern California
      Thanks Matt, I will have to see what a new regulator does. I was very tempted to swap it out with a C5 in the shop...just to see if this regulator runs the Vette.
      Any one have stories of this regulator not working??
      May 2002
      Northern California
      Ok update for those that are curious...we swapped out the regulator and it still will not pass fuel. It is now determined that the problem lies in the pump area. Dropping the tank sunday. {:Allen please move to FI or LS1(OR where ever you see fit) section. delete this part please} Thx....jackaxe
      May 2002
      Northern California
      ok, lables in picture is wrong...outer is to fuel rail and inner port is return. thanks everyone.
      Los Altos CA
      Quote Originally Posted by MrQuick
      haha SO I WAS RIGHT?!?!
      Mar 2002
      Redwood City, CA
      Quote Originally Posted by ilovefirstgens
      Yeah, maybe, but what happened on the rest of the car?
      Allen Ortega
      Los Altos CA
      Quote Originally Posted by zbugger
      you win some you loose some...
      May 2002
      Northern California
      its tough when you have 18 guys saying the sky is green and one guy telling you its blue. you just won't know till you look for yourself. I guess its true, you can't always believe what you see on the internet.
      69LAnd
      i was right!! lol
      Rick M.
      hMMMMMMsss....
      1969 Camaro real RS SS DSE LS3 6M TWiiN TURBO in the make!(taking forever!!)..any donations apreciated hehe
