Thread: To build or crate?
11-04-2004 #1
Starting The Transformation
- Oct 2004
- Frisco, TX
- 194
To build or crate?
In general is it more cost effective to have a shop build you an engine or to buy a crate?
11-04-2004 #2My buddy is an engine builder, and has done a few for me in the past. When its time to repower the camaro he has said there is no way for him to compete with crate motors. With the cost of machine shop fees, and the fact that these assembly line type engine builders, or factory crate motors get the deep discounts from vendors(massive quantity). To play devils advocate, you maybe sacrificing quality, and don't forget Trust and reputation. I know my friend stands by every engine he builds, and alwasy helps with the tuning as long as its in the car, and if something should break, he will own up to it if its his fault or not. You might be on your own going the other route.... I'm in the same position as you, I really want my friend to build it for me but I could save several hundred to several thousand by going crate....
Camaro Convertible Build Pics - http://s447.photobucket.com/albums/qq198/rob07002/
www.musclerides.com
Rob Stevens
11-04-2004 #3I think it depends what you want out of the engine. If it's a mild street motor, I don't think you can build one that's as good as a crate for the same price, unless you are a swap meet hero. If you are going for something wild or unique, then I think that might be a different story. It would depend on how much assembly you are going to do yourself, plus you can spread part purchases out over time, hard to do on a crate motor.
11-04-2004 #4I purchased a GM Performance ZZ383 about 2 months ago and have been extremely satisfied. I would make the same purchase if I had to purchase another motor. With that been said if you are going to modify the motor to run over 600 hp you will need to internally balance the motor so you are back to the machine shop and that would eat up your savings.
11-04-2004 #5
