      Aug 2006
      Hello, new member, HotRod Designer
      Hello, I was directed here by a fellow member of Lateral-G. I don't have a notable car myself, but I do design work. I will try to post some examples of Hot rods some time.
      Designs I have done, none except the 69 Firebird have been built.
      1949-52 Ford Tudor
      1932 Ford with retractable glass top
      1948 Olds Rocket
      1970 Mustang Grande PT
      1949 Chevy Coupe
      1969 Camaro
      1969 Firebird
      1967 Rambler 2 door
      Designs I will be doing soon,
      1982 Camaro base or berlinetta PT
      1979 Mustang Ghia
      1970-73 Firebird Esprit
      1970-72 Nova
      1964 Skylark PT
      heavily updated 1970 Chevelle (like the 05 mustang ressembles the 67 FB)
      One of these designs is in the works to be made, no others ATM. I also do more modern designs, like a Concept I recently did for a Lotus Esprit replacement.
      I do allmy rendering on paper with Markers, so they are not as flashy as some done in CG, but accurate and funcional nonetheless.
      I also wanted to give Bob Johnson a big thanks, for using a real designer on his G-Force Cuda project. Without a doubt that car would have been nice but not on the same level if he didn't have Chris Ito pen the design. Thanks for showing others that a designer can help you make a really great creation.
      north central Iowa
      welcome aboard brian, I was hoping you would come check this place out,
      Jun 2002
      Long Island, NY
      Welcome to the site.
      Jun 2006
      Hiawassee,GA
      Aug 2006
      Thanks guys,
      TO tell you the truth, I was a bit intimidated, seeing as I drive a POS and there are a lot of heavy hitters on here.
      But, then again I can design pretty well, so maybe I'll get a few gigs out of here.
      Here are a couple of line drawings that need to go through the rendering process. Thanks again
