    Thread: Carb Crazy
      Carb Crazy
      now i havent been around that much lately becuase ive actually got own business of the ground doing susp mods and lots of body work but anyway im a carb retard iv got a 327,202 160 vlv,536 lift cam pertronix hei and the car seems very lazy as far as throttle response it has 6 psi fuel 45 power vlv 76 main jets,its a vacum secondary electric chocke holley 750 the secondaries dont seem to open up no matter how much throttle you give it any and all help greatly appreciated
      Aug 2001
      Connecticut
      Definately check your vac. secondaries, maybe the wrong spring or a bad diaphram? Also a 4.5 power valve is going to open way too late for such a mild engine. Most holley's ship with a 6.5 which is good for most applications as a starting point.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Southern Indiana
      pv
      Actually 68 thats wrong the 4.5 is pretty much perfect in my opinion.
      As for the lazy part its probably the secondary air valve spring being to stiff.
      Get a new secondary diaphram ,a quick change kit and set of springs,,, you will probably need to use one of the lighter springs I usually use one of the lighter yellow ones, but with a quick change kit you can swap them at will.
      what you shoot for is a smooth steady progressive acceleration not a big stumble as most people make the mistake of set it for.
      Good luck and dont worry about the power valve I use a 4 or 4.5 and I only have a GMPP LT4 HOT roller.
      Lee
