      Aug 2006
      Connecticut
      New Shifter For TKO600!!
      Have anyone used a Pro 5.0 shifter, or a Steeda Triax on a TKO600? the reason I ask is because I have some difficulty gettin it into 3rd when I jump on it. It seems like the shifter gets losts between 3rd and 5th and then you end up missing. Ive heard nothing but good things about the pro 5.0 from T56 owners and I wonder if the experiance would be the same on the TKO. It came with the stock hurst which is a short throw and is ok...but im looking for better feel and something that gets into 3rd easier.
      GTO, 2009 Camaro or maybe a pro-touring machine? Only time will tell. The Nova for now!
      Encinitas, CA
      I have not tried one but I have sen them and they look like quality units. I would give it a try.
      Jeff Mortenson
      Feb 2006
      Columbus, GA
      Jeff,
      Do you have a good source for shifter handles for my TKO. I bought it from you in July of 05 and still havn't got it in the car. I should be able to get the engine/tranny in in a couple of weeks:3gears:
      1970 SS Camaro, 502 RamJet, TKO600 Tremec, 3.91 Moser 12 bolt/Detroit Tru-Trac, C5/Z06 Brakes.
      Detroit Subs
      I used a Steeda Tri-Ax stick & knob on my TKO 600 with the original shifter - but haven't fired the car up yet to actually try it. It feels good on the jackstands though!
      Encinitas, CA
      Just choose your favorite Hurst, or other brand, stick that has the two bolt hole pattern. If you go to Mrgasket.com (Hurst) you can check out their catalog which gives the dmensions of various shift sticks. If you can't find it, call us.
      Jeff Mortenson
