    Results 1 to 10 of 10
      Portland,Oregon
      What steering column to use?
      for my 69 camaro I want to replace the steering column with a tilt column.
      What is better the flaming river or the I didit one.
      Also what did you you guys do with the key ignition.
      Robert Braga
      1969 Camaro LS2/T56 D1SC
      www.automotivedesigneng.com
      US Collision / Mortenson's Custom Touch / DPE Wheel / Tim Bruning / Columbia Parts Company
      florida
      column
      Ijust bought a ididit column thru gp store and it has the ignition in it.that is probably the main reason i went with ididit.it is a direct bolt in and you can choose how long you want the shaft.
      ididit for me too. I wanted the key in the dash, and they made it a custom length for me.
      jp
      ​John Parsons
      Jun 2005
      Omaha, NE
      We have used flaming river in the past I like their stuff for street rods. We have an ididit for a 69 we are currently building it's really nice. We did a chrome setup so it shines...
      Jeff
      Portland,Oregon
      what ignition do you use if you don't want the ignition on the column.
      The ididit column with the key doesn't look right to me. It doesn't look oe enough for me.
      Robert Braga
      what ignition do you use if you don't want the ignition on the column?
      AAW's wiring kits come with an ignition switch for the dash (just like OEM). I used their HiWay 22 kit.
      jp
      ​John Parsons
      Feb 2006
      Elk Ridge, Utah
      Im CHEAP so i used a 2nd gen tilt colum
      I took it completely apart replaced the ign switch lock cyl turn sig swith sand blasted all the pieces and painted it with a rattle can then wetsanded w 1200 and hand polished it
      it also has flaming river stainless turn signal and tilt levers not shown in the photo wich aare about an inch shorter and fit nicely with a smaller diamiter steering wheel
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      Wisconsin
      I used the Falming River unit in the Nova. I rewired the car using Ron Francis harness and actually deleted the ash tray by welding it flat and installing the key in it. That way when the car is on or off I can flip up the ash tray and the key is gone. Cleans it up a bit in the car. just my .02
      Justin
      73 Nova, 502 ci, TKO600, Mosier Eng 12 bolt, 6 point roll cage, Wilwood rear discs, factory front discs, 250 HP nitrous, subframe connectors, Slide-a-link trac bars, 17" Boyd Coddington Smoothie II's, and Hotchkis TVS kit.
      Melbourne, FL
      I have heard that the Ididit versions use the original mounting hardware. What all do you actually reuse on a 67 ?? I know there are mounting brackets that mount to the steering wheel that attach to the under dash bolts. Also there are pieces that cover the bracket on teh steering wheel. Are all of these pieces reused on the Ididit models so it looks like a stock mount ??
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      67 what? Based on your username, I'm guessing Firebird, so I can't help you.
      On my 67 Chevy II, all my stuff was custom fabricated: column to firewall, column to dash, column to steering wheel adapter, etc.
      jp
      ​John Parsons
