Thread: 383 stroker timing?
08-08-2006 #1
383 stroker timing?
what should be about the right timing for this block?
specs• Hydraulic Camshaft
• .050 Duration: 234° Intake; 244° Exhaust
• Advertised Duration: 300° Intake; 310° Exhaust
• Cam Lift: .325 Intake; .340 Exhaust
• Valve Lift: .488 Intake; .510 Exhaust
• Lobe Center: 107° Intake; 117° Exhaust• Forged steel crankshaft
• 10.3:1 compression ratio
• High performance rod bolts and nuts
• High rev lifters and performance valve
springs with retainers
• High volume oil pump
• Double roller timing set
• Flat top hypereutectic pistons and moly rings
• Harmonic balancer
• Screw in rocker studs
• High performance stainless steel valves:
2.02 Intake; 1.6 Exhaust
• High performance camshaft
• High performance bearings
• High performance head gaskets
• Four bolt main block
• Dart Iron Eagle heads
• Full roller rockers
• With Flex Plate
69 camaro, 383 stroker, 700r, 3:73 auburn, JL stereo, marquez lights front/back, adj qa1's, custom dash, sts swaybars 1 1/4-7/8, global west a-arms/subframe connectors, suede interior.
http://hobbystage.net/camaro/jigga99/
08-08-2006 #2750 edelbrock carb and rpm intake
08-08-2006 #3You'll kinda have to play with it. I'd baseline like this:
With that much overlap you're doing okay with pressure down low, so find a curve that starts you about 20* at idle and moderately fast advance to total at about 38-40* at 2500rpm.
Play with it like that and see how it reacts.
08-08-2006 #4
