    Results 1 to 20 of 28
    Thread: Fuel Pressure
      Macon, Ga.
      Fuel Pressure
      What is the normal fuel pressure you guys look for in a LS1 conversion? I have 65psi in the fuel line coming from the tank, but it drops to 45psi after the regulator and the car will not run now. Isn't this too low? I was thinking it should be 50 or 55?
      Bill
      Trailers are for BOATS!
      OEM fuel pressure is 58 psi.
      My FAST setup is running 42, so it's just a matter of what you're tuned for. IIRC, you're using the OEM computer, right? 45 is a bit low for that, but I'm surprised it doesn't run at all.
      jp
      John Parsons
      58.8 psi at the fuel rail to be exact.
      Anddrew
      Macon, Ga.
      Thanks guys, that really helps. I guess that is why is has seemed to be falling off a bit lately, regulator must be bad? I will order another one tommorrow.
      I wonder what is the least pressure that the car will run on? Must be about 45psi.
      The regulator Street and Performance supplied with the blower is a OEM GM part. No adjustment at all, it is what it is. Any suggestions on an aftermarket adjustable one?
      Bill
      I'm a little surprised also that it doesn't run at all.
      Where is your filter located? Could it be that causing the pressure drop?
      Little free trick. If you intend to replace the regulator anyway, try compressing the end. That will pre-load the internal spring and should bump the pressure up.
      Macon, Ga.
      I found a AN cap and closed the return. That brought the pressure to 66psi. Still will not run, looks like I got other issues.Sad thing is, it ran about two minutes after I changed the fuel filter??????????????
      Bill
      Jul 2003
      Anaheim Hills, CA
      filter in the right way.. it only flows in one direction
      1968 Track Rat Camaro:
      Dunwoody, GA
      Every Magnacharger I have done has a steady 55 psi on the fuel rails, even under WOT. The regulator is taken off whatever engine the unit happens to be going on and installed in the fuel rail. I believe all the regulators are the same reguardless of engine. I just have never bothered to run part numbers to verify though.
      Have you bothered to scan the ECM? Did you install an SES light somewhere on the car? Coil packs plugged in? Just thinking out loud.
      Trey
      ~ Jon Hammond
      Macon, Ga.
      Thanks, I am going insane with this damn thing. Checked codes, replaced parts, and still nothing. checked for skinned wires, nothing. It will crank and run about 4 seconds when cold. Then run about 1 or 2 seconds from then on everytime you try to start it. I am beganing to think something is getting hot and sending a bad message or maybe the computer itself is taking a dump. Either way, I am clueless. I do have a new regulator on the way, but I swear, I think the car should still run with the 45 psi. It does for about 4 seconds.....
      Bill
      Damn Bill, you need to get that thing running!
      I'm with you: I spent 10 weeks with mine to get it running right. Mine will run at 20 psi (I know this because I often forgot to turn on the fuel pump, or would disconnect it before turning off the engine). So something that stops the engine -- right now -- is more likely electrical or ignition.
      Does it start right back up after it dies? Or do you have to crank it awhile?
      jp
      John Parsons
      Macon, Ga.
      Right back up but cuts back off in about a second.
      Bill
      May 2002
      Northern California
      check for codes, maybe you have theft cut off?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      If it starts right back up, I really doubt fuel pressure is your problem.
      You need to get diag info from the computer. Got a code reader?
      jp
      John Parsons
      Jun 2006
      Toronto Canada
      Yep, there will be codes sending you in the right direction
      Dunwoody, GA
      Bill did you not have any codes? I find that hard to believe you couldn't have any with this problem. What PCM are you using?
      Trey
      ~ Jon Hammond
      Macon, Ga.
      Yep, two codes, one about a low frequency on the MAF, and one about the CPS. Replaced both with known good ones and no help. I did figure out tonight that it would run with ether, but still not solution. I am headed to Orlando tommorrow to a guru that promises to not only fix it but do the dyno I have been needing too. I need a couple beach days anyway..
      Bill
      Orlando, eh? Mike Norris?
      Tell me more!
      jp
      John Parsons
      Macon, Ga.
      Yep, be at his shop Saturday.
      Bill
      69LAnd
      it looks like vats ...which it could happen if you have a stock computer and it uses one of those vats bypass modules instead of vats delete but if the fuel pressure dropped sometimes the engine floods trying to gasp for fuel and it wont start next time to try to start it up (it happened to me !! but most likely is something simple
      Rick M.
      hMMMMMMsss....
      1969 Camaro real RS SS DSE LS3 6M TWiiN TURBO in the make!(taking forever!!)..any donations apreciated hehe
      long island NY
      I'm curious as to the size of the fuel lines feed and return you are running for the lsx motors
