      Jun 2006
      Central Point,Oregon
      Do I Need to weld sub frame?
      I have my 69 Camaro apart. My question is do I need ,Or would it be to my advantage to weld the sub frame in between the factory welds. I will have DSE sub frame connectors with solid bushing and Delalum bushings in the A-Frames, Hotchikis TVS.
      Thank You
      Jun 2005
      Louisiana
      I welded mine all the way down the seams, just because. I doubt itll ever make a difference, but if its already apart, why not?
      Aug 2006
      Hampton Roads, VA
      I do not have mine welded but if I had the car stripped down like you do, I would weld them in place. That's one less place that can move and flex.
      Paul
      Las Vegas, NV
      I just did this to my `67 frame not too long ago. I also added welds in places such as the backside of the the middle frame mounts. Like CDjr said, I doubt it will really make a huge difference, but my frame was off the car and had already been media blasted, so why not?
      Doug
      67 Camaro - Project: Retribution
      "Honda: The most efficient means of converting gasoline into noise without the side effect of horsepower."
      DUBUQUE IA
      i also did it to my 69. why not if its out. some of the factory welds had came apart.
      barry
      just go slow so you dont warp it, i wouldnt just weld from one end to the other.
      Jun 2006
      Thank You
      Thank You everyone for the replies. I will be welding the sub frame. That was something we used to do in the old days of stock car racing I wasn't sure it would be appropriate with this.
      Mchenry, IL
      Never hurts, the less chance of a flex point the better
      HE WHO DIES WITH THE MOST TOYS WINS!!!
      2012 Camaro ZL1 M6
      1978 Camaro Z-28 C5 Corvette Hybrid
      1999 Jeep Wrangler
      2004 Acura TL
      2002 Chevy Silverado
