Thread: 2 high front end
08-03-2006 #1
2 high front end
well i have yet another dilema, I have moroso trick front springs, 3 way adjustable shocks up front, stock leafs with poly pads, and cal trac bars with 3 way shocks in rear also, I have 17x8 centerlines in rear with 255/40 17 and 17x7 with 225/50- 17 in front. i cant run drop spindles because i havent found any good ones that the tie rod wont rub the rim, and im pretty damn sure i cant cut, nor do i want to cut my trick springs. I would like the front to sit around 2" lower in front because i have alot of air between the tire and fender lip in the front and none in the rear and it looks stupid. any suggestions?
