08-02-2006 #1
Paint or Powder Coat - Engine / Tranny?
The question I have is whether it is better to paint or powder coat an engine or transmission. I am currently swapping transmissions - and I was reading that powder coating an engine or transmission causes more heat to be retained in it. I heard that the temp difference is between 5-10 degrees. Is this true? The price difference is like $50 between having it painted or powder coated - but if powder coating is going to cause more heat on the tranny - then I will spend the $50 now to have it painted - to help the cooling later on.
Any thoughts?
08-02-2006 #2
- Jul 2006
- Chesapeake, VA
- 678
Somewhere in the back of my head I think I've heard of transmission cases being powder coated. On the other hand not only is powder coating likely to retain more heat than paint because it's thicker, it also melts.
08-02-2006 #3If your engine or transmission sustains a heat at or over 400* F to melt the powdercoating, I think you have bigger problems.
Originally Posted by jaybee
The needs of the many outweigh the needs of the few.
08-02-2006 #4
Originally Posted by toxicz28
WELL SAID !!
08-02-2006 #5
