      TKO VSS pinout question
      The TKO has a VSS (maybe correctly called the OSS: output speed sensor) that can be used for a speedometer.
      The connector has two pins: one is the signal, and the other is the signal reference (which can just be connected to ground).
      Anybody know which is which?
      thanks!!!!
      jp
      ​John Parsons
      Oct 2005
      I just picked one of the two wires and grounded one and wired the other to the speedo signal wire off my auto meter speedo.. Seems to work fine.. Finding the proper pigtail for the sensor was another story, was told by the dealer who I bought the tranny from that it was a chevy vss but in fact it was a ford unit, I used a ford pigtail thats actually meant for the diff of the newer trucks
      Good luck
      Tom
      Tom,
      Exactly right, and thanks. I'm just wondering which of the wires is which, because the wiring comes up through the floor and the ground goes one way, and the signal another.
      Oh, and I found that a GM CTS connector worked perfectly. I happened to have one lying around, otherwise I'm not sure I'd have ever figured that out.
      jp
      ​John Parsons
      Welland, Canada
      Just a FYI here, for anyone who runs into problems finding a pigtail for VSS output on the TKO when using electric speedos.
      I used a Calterm-GM multi use sensor plug p/n 08692.
      On the back of the box it states...
      GM 1995 to present sensor plug.
      Coolant temp, brake fluid, washer fluid, igniyion module.
      If you lookup on Rockauto.com a 199? whatever for a coolant temp sensor plug, many other companies making this pigtail will come up.
      HTH somebody!
      Dean
      69 Camaro 355-3.73 Moser Truetrac-TKO600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's
      ST U/LCA's-GW Del-a-lum's-Lee p/s
      Dean,
      Good information. Hope it helps people without connectors lying around.
      Can you tell which of the pins is ground?
      jp
      ​John Parsons
      La La Land, CA
      John-
      From T56 experince with VSS 2 wire pigtails, it doesn't mater which one is ground, and which one is signal.
      Tyler
      Tyler,
      Cool! I'd bet the Tremec did the T56 and the TKO the same way. I'll go with that.
      thanks!
      jp
      ​John Parsons
