Thread: coilovers
07-30-2006 #1
coilovers
should i run a rear coilover set up on my 65 chevelle? if not what do u suggest? and how hard is it to mount the rearcoil overs?
https://www.pro-touring.com/forum/sh...ad.php?t=22724
65ss chevelle
95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
63ss nova
350:cam headers,roller rockers.pete jackson gear drive,
th350 shift kit 3,500 stall
3:73
**Drive it like you stole it!!
07-31-2006 #2It depends on what you're looking to do. A well tuned suspension with traditional shocks/leafs/coils (not familiar with your car at all) can ride and run pretty dang well. Don't go coil-overs for the bling effect, go coil-overs because you value the ability to quickly change the ride height and damping/rebound settings for your suspension... that is, if you are going to track it.
07-31-2006 #3
Full Blown G-Machiner
- Aug 2004
- Boston MA
- 686
Coil overs aren't really for changing the ride height of your car. Their explicit benifit is the ability to set wheel weights. Gross changes to ride height should be done by design.
1967 #s RS
07-31-2006 #4i was doing coilovers becuase i was told drop spindles on an a body car arnt that grate by a few different ppl on this site and lateral-g.net
65ss chevelle
63ss nova
3:73
07-31-2006 #5completley agree, I was reffering to what 9 out of 10 people on this site would use coil overs for as almost all the cars here are street driven.
Originally Posted by wendell
The issue with drop spindles is tie-rod to rim clearance, if you plan on going with a wider than stock wheel you'll almost definately face intereference issues.
