      Jun 2006
      Elizabeth City, NC
      My '52 styleline project....
      I know, I know, it is a far cry from a camaro, chevelle, nova, or even that badass rat rod bonneville I saw a couple of days ago on here, but this is what I am going to start here as soon as I can.
      A run down on the car: It is a 1952 Styleline Special Sport Coupe. I found it in south Texas through a friend and ended up buying it for 1400 bucks, it had the original(so i was told) motor and trans in it, still running and all it needed was some brake work. Well when I finally went to pick it up, it needed way more than just some brake work, but it had only 92K original miles on it and sure enough, it still ran.
      After decoding the block, it turned out to be a 1954 236ci I6, not the original babbit rod motor I was expecting. Oh well there goes the restore idea, so now I must mod it!
      I bought a LM7 from a 2002 GMC Yukon (for those that dont know, it is an iron block, aluminum headed 5.3L based on the ls1 design) and a T56 M6 tranny to take advantage of the double overdrive it offers up. I also purchased a complete IRS rear from a '84 vette(it is a D36, not a D44, but it work for the power level I am going to be putting through it) and an almost complete, minus the drivers upper control arm, front suspension assembly with the rack and pinion. I picked up the driver's control arm at a corvette car show and swap meet in Houston for 80 bucks (a lot better than the 2-300 dollar price tag I was finding everywhere else). I got all of the accessories, harness, electric throttle body, throttle actuation computer and its harness/pedal assembly.
      I plan on doing some extensive body modifications including but not limited to: cjopping it, sectioning it, nosing it, decking it, frenching it, shaving it, pancaking it, etc.
      Here are a couple of photos after I took the 6 cylinder/3 spd auto tranny out of it and took the front grille assembly and fenders/hood off.
      Phoenix, AZ
      D-Lux,
      That's a very intriguing project you're working on. I think most on this site appreciate the originality of doing something different (not that there's anything wrong with mainstream either - most of the time). I also gotta ask, what's with the crunched Pontiac in the top picture??
      Jun 2006
      Elizabeth City, NC
      It is a customers '68 goat 'vert. I am restoring it, sort of. It is getting the pro touring spin put on it too. It is going to be candy black based with orion silver.
