    Page 2 of 2 FirstFirst 1 2
    Results 21 to 23 of 23
    1. #21
      Nov 2004
      Eastern Washington
      I actually just bought a junk pair on eaby to play with. They should be sent Monday. I am going to try a lot of different things. I will try grinding them down, make a mold and also try modifying the lens.
    2. #22
      Nov 2004
      Eastern Washington
      Quote Originally Posted by Midwest Performance
      As an experiment I made a mold of a 1969 Camaro model and used it to make a wood body for a Pine wood derby car(ground up sawdust and wood glue). I used Smooth-on and used the dragon skin. For a tail light model I would use a stiffer mold material that they sell. You need to get a tail lights from ebay cheap and modify them to meet you need and make a mold. They would keep the reflector lense from the inside that makes it DOT legal and have the outside custom like you want. As far as that goes if you smooth out a stock set of tail lights and like how they come out use them.
      I am working on a custom smooth set for my 69 camaro right now. I am not happy with the profile I have yet.
      There is a guy in California that if you have the plug(part to be made) he will make the mold for you and cast them. I don't remember the site anymore off hand but will try to look. With all things custom even if you already have the plug designed the molds would not be cheap.
      Attached is the pictures of the mold and parts from it and my taillight profile test piece. notice the roughness of the top of the car that is due to me not using enough mold material to make it thick enough there.
      Later Kevin
      Hey that is pretty slick! Its nice to see this in action. Is that an epoxy mold or a silicon mold that you made? Is that the aluminite stuff?
    3. #23
      Jan 2004
      Iowa
      Mold was a 2 part silicone made by "Smooth-on"
      This is the link to the stuff I used http://www.smooth-on.com/. I agree that you need to find a UV resistant product to cast. I am not sure as what I would use yet.
      Later Kevin
