      Ortonville, Michigan
      Reverse Lights For Truck
      Hey Guys, Im looking to hook up extra reverse lights for my fullsize truck and I need some help with the wiring.Wanting to have extra lights but working with a 3 postion switch(on-off-on).
      First postion will be triggered by factory reverse lights,
      Sec. will be off and third will be constant on.
      Ive got all the wiring and relay and switch just having trouble figuring out how to wire. I'd also like to wire in a indicator light to show when lights are on in the 2 positions. Call me an idiot but this is my first time wiring a relay.
      Thanks in advance,
      Chris
      1971 RS Z28 Pro-touring thing......will it ever be done??
      bump
      Feb 2006
      Elk Ridge, Utah
      Would it help If I told you that the wiring diagram is on the side of the relay?
      relay is used like this
      30 goes to fused battery or fused keypower
      87 goes to what you want to power when the relay is activated
      87a goes to what you want powered when the realy is NOT activated (If you need this it can be usefull)
      84 goes to ground
      85 goes to your switch or whatever you want to activate the relay with, Togle or reverse lights
      The rest of it I can not find a way to put it simply enough
      unless you know what a diode is.or you can use 2 relays
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
