    Results 1 to 17 of 17
      Nov 2003
      Paradise, Ca
      Particle size required to damage a turbo
      Hey boys and girls. I'm wondering how large a piece of 'whatever' it would take to damage a turbo. Check out the pictures of a set of headers I recently had the chance to critique. They are supposedly 321 stainless. The small piece is a sliver left from sloppy end prep where the welder didn't get full penetration, and the large piece (the size of my thumbnail) is a piece of the coating that I broke off with very little effort with my fingernail. The coating puddled and cracked. There is also a couple pieces of media left in one collector from media blasting prior to coating.
      Before anyone asks, I am not at liberty to say who made these.
      -Matt
      Oct 2005
      SoCal
      Ehh I wouldn't worry about the coating and stuff going through the hotside. If it were my car I wouldn't be thrilled with the coating peeling off, but that little piece won't hurt it. The turbines are quite a bit stronger than the compressor just due to the nature of the beast.
      Aug 2001
      Wilton, CA. (Sacramento)
      Thanks for helping him Matt.
      Jody
      Nov 2003
      Paradise, Ca
      Thanks ProStreet. What's your thoughts on the tubing flash and the media in the collector?
      Jody, it's what I do.
      -Matt
      May 2002
      Northern California
      It happens...are these prototypes?
      I've seen turbos pass larger things but It would have been nice to take the extra time to brush and clean it out better. Sometimes people don't think to do this cause its just going to pass harmlessly out the tail pipe.
      BTW, who made these? 8P
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Oct 2005
      SoCal
      I would try to get the blasting media out of it as much as reasonably possible but if a little is there and passes through the turbine it won't hurt anything. You would be shocked at what can pass through the hot side of a turbo with out hurting anything, not nearly as delicate as the compressor side.
      Did they do any clean up work on the headers? Seems like all that flashing and such should have been ground off prior to them being coated.
      Kinda curious why they didn't bother to use a nice merge collector with a center transition and such. If you're going all the way with stainless might as well go big IMO. kinda like
      Nov 2003
      Paradise, Ca
      Vince and ProStreet: These headers are one of the worst I've ever seen, and they are not prototypes nor one-off's. They are a part number that someone sells. And they aint cheap. I'm making a replacement set for the owner, so these won't be used.
      Here's another thread I started on another forum asking about another potential problem with these headers.
      ProStreet, a set of Burns merge collectors was ordered earlier this week.
      You'd think, wouldn't you?
      -Matt
      Oct 2005
      SoCal
      Wow thats a production part? I thought this was just a home job someone tossed together in their garage.
      How does the rest of it look? After you get past the part of them not bolting to the heads that is.
      Mind posting a pic of the rest of it?
      Oh and lets see some pics of what these are getting bolted too! I always like to see other turbo projects.
      Nov 2003
      Paradise, Ca
      Here's a few more pictures. I think they speak for themselves. I will say that they look fine from about 10' away. I'm not going to post a picture of the entire header because it may give the manufacturer away, and I'm not in a postion to do that. I'll be sending a link to this thread to the owner though, and it's up to him.
      The owner won't even let me see pictures of the car! It's going to be a SEMA car, and I guess they are keeping it under wraps. I've been assured that it will be incredibly nice though. From what I hear, it'll be an aluminum SBC running in the neighborhood of 20lbs of boost.
      -Matt
      Aug 2001
      Car is very cool with several subtle changes from the norm. And yes, the aluminum Brodix engine should run very well. I had the pleasure of assembling it for him, and he cut no corners.
      Jody
      Apr 2003
      Central Valley, CA
      I'm having a very hard time keeping my mouth shut about these... but I'll be a good boy and be quiet about the vendor.
      Matt, thanks for the analysis and for posting more pics than I had seen previously, my opinion of them just went down even more... I wouldn't take them for free unless I needed a new doorstop! I wish I had a chance to handle them in person as you have although the pictures were pretty damning by themselves.
      If a little piece of that coating went through the hotside at idle or cruise the hot wheel would probably be OK. Now if the hot wheel was forced to digest a piece of that coating while spinning who knows how many tens of thousands of RPM at full boost, I wouldn't rule out the possibility of chipping the leading edges on the wheel.
      You can't even get reduced diameter 12-point bolts in 6 of the 8 holes...
      Maybe you could use these as the centerpiece of a $4000 HabiTrail setup for your Hamster. I dunno. How large of a piece of coating can a hamster pass without being damaged?
      1969 Chevelle
      Nov 2004
      Roanoke, VA
      Quote Originally Posted by ProStreet R/T
      Sorry but my "home job" headers look WAY better than those slapped togeather pieces not mention Id be embarrassed to put a part # on them and sell them to anyone.
      The above pics are EXACTLY why I build/fabricate everything I can myself. I dont mind spending good money but when parts show up looking like they were thrown togeather over a weekend and a 12 pack it chaps my hind end.
      BTW, as ProStreet R/T said the turbine side is a little more durable than the compressor side so it will tollerate small debri unless it consists of rocks/internal engine parts. The compressor side is a whole other story though....just looking at it wrong can cause damage LOL.
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
      Feb 2002
      Springfield, MO
      The top ring land of a piston will hurt the wheel!!
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Mountain View, CA
      Those kinda look like dooky.
      True T.
      My blog
      I'd send it back and demand my money back.
      Please post the name of the vender so none of the potential buyers and fellow hotrodders will have to go through this same bs.
      Thats just plain ****ed up
      Dec 2000
      NE Florida
      uh, yeah- I'm probably going out on a limb here, but I'm sure that they haven't explored the ISO-9002 issue yet. Wow; Weld-on headers!
      *** stupid comment removed ***
      Dec 2000
      NE Florida
      removed my bad humor for fear of tainting a good name- people work too hard for that ****
