      San Francisco
      67 Camaro Radiator Sizes (Dimensions)
      What're the dimensions of a 67 Camaro radiator? I don't have my car right now and I want to order the radiator now through Summit. I have a 400 SBC and a TH350.
      I wouldn't mind a stock size but I would like a larger one even if the core support hole is smaller than the radiator. What's the largest radiator anyone has put into their first gen Camaro? Thanks
      Caledonia, MI
      I had a BeCool in my 67 rs. It was 26 X 19 which I believe is the same size as the stocker.
      Jason Mitchell
      1969 Camaro @ Dutchboys
      Ontario, Canada
      I used a Summit universal alum. rad in my '71 Nova. The core measures 23"x19". It took a bit of modifying to make it fit, but it was cheap enough that I think it was worth the effort.
      I'm also using a repop rad support. The rad opening is the same size as the big block SS Novas and the rad core is the perfect size for the opening.
      Ken
      My other car is a Vega.
      Oct 2003
      31" radiator
      I know if you remove the core support braces you can fit a 31" x 19" radiator.
