      Washington State
      Best way to purchase a LS2?
      What is the best way to purchase a LS2 and what else I need to run a LS2 in my 69? I know I will be getting all of the cutom stuff needed from T56.com. I just see so many ways from buying a crate engine and ECU, harness to buying a take out, but which is really the way to go?
      69 Camaro RS/SS convertable now being rebuilt again, out with the old in with more new
      ETA, last time I'm tearing it down!!
      I bought a LS2/t56 gto pullout sold the computer/harness
      and put on a Speartech harness with LS1 computer, had to
      use LS1 knock sensors and LS1 alternator $110 from Murrays Auto.
      Used a vette pedal and module to control the drive by wire T.B.
      Worked out well. Also the modified ATS f-body t56 hydraulics don't
      work with the gto slave must switch to a f body -different fitting.
      Cumming, GA
      Just depends on how much know-how you have, how much of your time you want to spend on it, and what your goals are. Some people want "turn key" 500hp and some want a junk yard take out to pursue their particular plans.
      Todd B.
      Vengeance Racing
      Formerly at:
      Kurt Urban Performance and Wheel to Wheel Powertrain
      Washington State
      Id like 500 horse turn key.
      Apr 2003
      phoenix az
      ls2
      jeff schwartz has a good connection on factory crate motors.
      Jul 2003
      Anaheim Hills, CA
      The problem with LS2 pull out engines is that they are hard to find. Finding an LS1 is easy.
      I was very happy with my crate engine, but you need to budget in a few grand for brackets, harness, ECU and accesories.
      1968 Track Rat Camaro:
      Washington State
      I was either going to go eBay where there is a LS2 and T56 with ecu out of a 05 Goat or I'm going the crate route and a TKO600. Whats needed to bump up to the 500 horse mark I have been told just a cam change and ecu mod. Is it really that easy? After dealing small block gen 1 chevys for so long I have decided its time to change.
      Cumming, GA
      It would be difficult to attain 500 with a cam swap. We make about 550 at the flywheel with our stroked LS2.
      http://www.w2wpowertrain.com/pc-79-8...ected-ls2.aspx
      Todd B.
      Vengeance Racing
      Formerly at:
