      Mountain View, CA
      Covans center panel
      Anyone have one of these installed?
      http://www.covansclassic.com/parts/d...424.23.244.228
      It looks like it might require deletion of the center vent, heat/ac controls and radio. Or does it fit below? Tough to tell.
      Hoping someone has one installed and can lemme know.
      True T.
      My blog
      May 2002
      Southeastern WI
      It will definitely require deletion of all of the above. The steel will have to be trimmed (cut out) where the heater controls mounted and the center vent area for clearance of the rear of the gauges. Should have mine in within the next few days.
      Jeff
      Mountain View, CA
      Not feelin it then.
      True T.
      My blog
      I have one installed. You have to cut the heater and radio thingy. But it would return back to normal very easy if you have to. I just cut it thruu the wholes or like that so it would be easy to line up to original if I want to in the future.
      67 Pro-Touring Camaro
      ISMAIL
