    Results 1 to 12 of 12
      Nov 2002
      Finland
      Howto torque cylinder head?
      Ok so this is probably a total "n00b" question but here it comes:
      How should I torque my stock cylinder heads on my '89 350TBI engine? Is there a certain pattern and to what torque should i tighten them?
      All knowledge and experience is welcome
      Chris
      Fontana, CA
      There is a specific order, but it follows the "start from the middle and work your way out principle". About any service manual has it in there for an SBC. If I had access to a scanner I could do it for you.
      Nick R.
      north central Iowa
      http://www.small-block-chevy.com/assemblyspec.html
      its about half way down the page
      Aug 2003
      Prescott Valley, AZ
      how 'bout BBC? i couldn't find any specs on the web.
      It's shake and bake!!! and i helped!
      Drewco Homes
      Sep 2002
      San Jose, CA
      Small block
      Just call me Brett
      Nov 2002
      Finland
      Thanks guys!
      Chris
      north central Iowa
      Quote Originally Posted by harshman
      http://members.tripod.com/torquespecs/hi_po_chev.htm
      try this
      Aug 2003
      Prescott Valley, AZ
      Now that I know how to torque them on, how do I get them off in the first place. I took all bolts off, and attempted to lift the heads off by inserting a wrench into the water ports and heaving ho but nada.
      Drewco Homes
      north central Iowa
      I would double check to make sure you have all the bolts out, its kinda easy to miss one. then maybe stick a longer prybar in the water ports and heave ho.
      I see you live in prescott valley, do you ever go to the dirt track races up there?
      Fontana, CA
      Quote Originally Posted by Harshman
      Take a mallot and give the head a few smacks on the face. Then use a prybar in an exhaust port. S/B easy from there. It also depends on the gasket quality. Crappy gaskets stick everything together really bad. I always suggest at least the Fel-Pro blue stripe gaskets.
      Nick R.
      Aug 2003
      Prescott Valley, AZ
      Quote Originally Posted by justanova
      not yet. i'd liketo some day, i just haven't had the time.
      Drewco Homes
      north central Iowa
      have you been able to get your heads off? if the prybar in the port dont work I have had to gently tap a screwdriver between the head and block to get the head to loosen up, just be careful not to gouge the deck.
      If you ever get out to the track I pit for the 007 modified, we will be there sat night to see if we can put a win on the board.
