      Oct 2005
      maple ridge, B.C
      charger running rich
      hi guys
      i finally got my car back from the exhaust guy and he did a good job with the space constraints
      so now im trying to tune it to run, at the moment the intercooler is not hooked up so i can tune the efi without boost to pass air-care/smog test
      the problem :- the car is running rich and it seems to be getting worse, at first it was slight smell of fuel from behind, but now it is always pukeing out clouds of black smoke at idle, and under part throttle it gets worse and throttle response is mushy with even more black smoke,
      when i first drove the car to the muffler shop with my n/a exhaust it was clean , crisp and powerful. with the turbos (no boost just free wheelin) it is insanely rich,
      the efi is a cutler mpfi, a predesessor to the the holley commander. it tunes itself with very little exterior adjustments (acceleration enrichment, iac control, startup enrichment.)it runs of 4 sensors, map sensor, water temp, air temp and throttle sensor. could any of these be faulty and causing my problem??
      the injectors are 38lbs which will be changed for 50lbs before i boost
      if anyone has any ideas let me know... im listening or if anyone has knowledge of the cutler system???
      also i have a small trace of oil in one turbo intake.. is this a sign of poor drainback??? the pressure line is 1/4" and the outlet is 3/8"
      thanks for any input
      jason
