Results 1 to 9 of 9
Thread: Need to know about sandblasting
07-14-2006 #1
New to Pro-Touring
- Aug 2004
- 8
I was quoted $2500 to sand blast and primer my camaro. I have more time than money. what do you guys know about sand blasting that may help me out. Im thinkin that I would buy a sand blaster and some walnut shells or bakeingsoda.
what are good brands? Im thinking that i want a pressurized pot. what size do i need. any info and tip would be appreciated.
thanks
07-14-2006 #2i can tell you what needs blasting.. hahahahahh
07-14-2006 #3I tried blasting my own car-way more work than its worth to me anyway! I ended up getting it blasted by a professional. He charged $900 to do the body minus the front clip but including the underside. He then primed it with etch prime after which was included. I think your price is a tad high.
07-14-2006 #4
New to Pro-Touring
- Aug 2004
- 8
how are the media blaster on ebay? what grit sould i use?
Venomous Type what is a 96 VW Demon GTI? I too come from the vw scene. and own several vw's
07-16-2006 #5started out with a '68 V-dub myself! You may want to try and chemical strip it. Most people say that it is really messy and all but I did it and it really wasn't bad at all! Buy some Aircraft stripper(You can get it at your local auto parts store!) lay it on. Let it work in. Scrape it with a metal scraper. If you need to reapply do it until you get down to the primer and then reapply and use coarse steel wool. It will come out nice and clean and you will get to see every inch of your car and what is going on.
***Under Construction***
Build Update Link:
07-16-2006 #6
New to Pro-Touring
- Aug 2004
- Michigan
- 66
Without the proper compressor you would take forever blasting your own car. Pressurized is the only way to do it but they take a lot of air. Compressors get very hot and make a lot of moisture when blasting for a long period. I bet you could smoke a home improvement store bought compressor on one car. You gotta have something around 20cfm @ 100psi and that's minimum. Thats actual cfm out of the air hose and not the displacement cfm's that cheap compressors like to advertise. You will get it very hot with makes the moisture which is constantly collecting in your blasters water filter. Realistically a 5hp compressor isn't really enough to blast a full car. And I mean a real 5hp that is two stage, rebuildable, and pistons the size of a smallblock is still is lacking. Blasting sucks and that's why some shops get a premium but 2500 is outrageous in my area. I like to chemical strip the body like stated above and blast the seams. Someone without experience can take a nice panel and warp the piss out of it with sand due to the heat exherted on the panel during blasting. I've even used a blaster before to shrink certain creases in metal. If I don't want to use the torch on the area then a blaster will draw the metal also. Anyway be careful and experiment.
07-17-2006 #7
Rat Pack Member
- Aug 2002
- Waleska Ga.
- 2,722
