      Delaware, OH
      Slave-LESS hydraulic clutch - anyone using this type setup?
      Is anyone here using a slave-less hydraulic clutch set up (i.e. master cylinder only - see pic below)? I'm converting from mechanical to a master-only hydraulic set up and I'm looking for any tips/tricks/pros/cons/suggestions/etc. Anything you can offer on the subject.
      Oh, I'm running a TKO with a Centerforce DF clutch.
      -What brand did you use?
      -Any problems with setup?
      -Any problems with bleeding the system?
      -Issue with o-rings, seals, etc?
      Byesville, Ohio
      I use and sell the Tilton setups on TKOs. It is a slave less system, uses a hydraulic throw out bearing that mounts to the front of the transmission. I like it for the room, no slave hanging off one side of the bellhousing. Seems to work quite well, figure with as much racing experience as Tilton has, it's a safe bet. Uses a bleeder screw at the bearing, so bleeding is a non issue. I talked to the engineer that designed it as well, the seals were tested to an ungodly amount of time without failure, so that's some peace of mind.
      I'm using Quarter Master's Tri-Lite. It bolts to the back of the bellhousing, and seems to work well. Bleeding is done by a short hose that comes out the side of the bell, so you can bleed without unbolting anything to get to the TOB.
      jp
      ​John Parsons
      Delaware, OH
      Thanks for the unput guys. I have a hydraulic system from Classic Chevy 5 Speed, that a combo from ATS (master cylinder) and McLeod (t/o bearing). So far it's working well, but it's taken some getting use to vs. mechanical linkage.
