Thread: 2 bolt mains
07-05-2006 #1
- Nov 2005
- 16
2 bolt mains
I have a 454 with 2 bolt mains. I put a new BDS 8-71 blower on it, and it's underdriven.
The question is...is there anything that can be done to the lower unit that would help support or strengthen the mains short of taking the engine apart and drilling and installing 4 bolt mains.
When I bought the car, most of the work was already done. If I would have built the engine from scratch, I would have started with a 4 bolt block, but I'm stuck with what I have!
New Bolts, Girdle?
Dan
07-05-2006 #2
- Nov 2002
- Georgetown,TX
- 2,557
A good two bolt block with studs & girdle can handle probably a 1,000hp,Dan. Even without them,your block can probably handle 750hp,safely. BBC blocks are a lot tougher than small blocks.
07-05-2006 #3
New to Pro-Touring
- Jun 2006
- 37
I second the stud girdle advice. Modifying a 2 bolt block to 4 bolt mains actually weakens the block. Best to either start with a 4 bolt, or just stud girdle it.
07-05-2006 #4I wouldn't do anything special,I would either do ARP bolt's or just run it.
A splayed 4-bolt block is stronger than a factory 4 bolt.
I wouldn't worry about a BBC block is quite bit stronger than most think
07-05-2006 #5
- Aug 2004
- Texas
- 254
