Results 1 to 19 of 19
Thread: Big block Chevy cooling
- May 2003
- St. Charles, Mo
- 424
I finally drove my Nova for the first time to a local cruise but I am a little concerned with the temps.
I have a 427 Mark IV block with GM performane aluminum heads, Accel fuel injection, and it's using an Edelbrock reverse flow tall water pump. I'm running a 180 degree thermostat.
The autometer mechanical temp gage is reading the temperature from the middle of the passanger cylinder head. The fuel injection temperature sender is reading the temp from the water passage next to the thermostat. The problem is the two temps don't agree. When the fuel injection is reading 185 degrees, the mechanical gage is reading about 230.
The radiator is not overflowing but I did just change the oil and there was about 3 quarts of coolant in the oil pan. I went ahead and changed the intake gaskets, I was thinking it was leaking into the lifter valley. I don't think I have a problem with the head gaskets. There is no oil in the radiator, it is not pressurizing the coolant system and there is no coolant coming out of the exhaust.
What do you guys think? Two of my friends are running about the same set up but their engines never get above 190 and they are sampling the coolant temp from the cylinder head as well. The only difference is they are running standard rotation water pumps.
I had the car idling in the driveway and the temp climbed pretty quick and got up to 230. The EFI only read 185. I think it would have kept rising if I wouldn't have shut it off. I am runnign out of ideas on how to fix it.
Dennis
