      electric dry sump
      Hi all, have you guys seen that new electric power steering system thats out there? I was wondering, would that pump be enough to run it for a dry sump system? I really don't know what the requirements are for a dry sump pump as far as pressure/volume. You could maybe even run it in the trunk...?
      manuel scettri
      sooo....
      No ideas on this guys?
      manuel scettri
      Nov 2003
      Paradise, Ca
      Personally, I wouldn't even think about doing that. My reasoning is that if you lose your power steering pump, you can still steer....if you lose your dry sump pump, the motor is gone.
      -Matt
      That is true matt, but what are the odds of the dy sump pump not working due to a say a broken belt versus the electric pump failing? On a side note, is it even possible to install a dry sump and still keep all accesories?
      manuel scettri
