      Delaware, OH
      Hydraulic clutch master install problem - HELP!
      Yesterday I installed my TKO with a hydraulic T/O bearing and also installed the hydraulic master (NO slave actuator like with a T56, just a master cylinder). I bled the master, but the pedal has ABSOLUTELY NO pressure, I can push it down with one finger. I also noticed that when the cylinder is depressed, the T/O bearing does not move.
      I disconnected the pressure line from the T/O bearing, held my finger over the end of the pressure line and depressed the pedal. I can baaaarely feel a little pressure against my finger, but expected fluid to blow past my finger. Only thing I can figure is that the master is bad.
      Any thoughts??
      Thanks!
      Jul 2002
      Mesquite, TX
      Can this master be bench-bled? (or is that what you already did?)
      Delaware, OH
      I didn't bench bleed it, you think that is necessary? It certainly can't hurt.
      Jul 2002
      Mesquite, TX
      If you're not getting any output, I'd try that before returning it and getting another.
