      Abbotsford, BC Canada
      Front end components ?
      I am going to redo the front end on my Regal and I wanted to find out what you would suggest for better quality parts then stock. Looking for like tie rods and all the front steering components. I'm going with all Global West suspension parts and QA1 coil overs.
      Tim Baillie
      Owner / Publisher
      The Hot Rodder Journal
      Your Hot Rod Lifestyle Magazine
      www.hotrodderjournal.com
      Frederick, CO
      Here's some ideas:
      MOOG Problem Solver line-
      Tie Rod ends / outer ES2033RLT
      Tie Rod ends / inner ES2034RLT
      Lower Control Arm bushings K6421
      MOOG Enhanced Design-
      Idler Arm K6187T
      A front frame brace would be a great addition too. Makes everything work together better.
      Those are gbody part numbers ?
      I got the front frame brace, the rear one, the fender braces, the seat braces, basically if a gobdy had one or they made one I got them all now.
      Just trying to decide on which sway bars to go with.
      Tim Baillie
      Owner / Publisher
      Frederick, CO
      Yes, they're all gbody #'s. Sounds like you've got the braces covered.
      I'd give Mark at SC&C a call about what bars to use, he's very knowledgeable and experienced with our cars.
      Larry.
      ('85 and '88 SS)
