    Results 1 to 20 of 27
    Thread: Twin Turbo Help
      Feb 2006
      Southeast Louisiana
      Twin Turbo Help
      I've talked myself into the twin turbo set-up for my 68 Camaro, but I need some recommendations on how to build the motor to support the boost. First, let me say that my goal is to have a streetable car that runs 10.50's. This should be easliy achievable from what I have heard. The car has a 350 2-bolt main block. I will be adding aluminum heads (not sure of what brand or cc). What I'm not sure of is what rotating assembly (forged or cast), pistons, and especially cam to use. I'm looking at probably 12-14 psi boost with GN turbos. Any help would be greatly appreciated. If there is any additional information that is needed from me, let me know.
      1968 Camaro, 350 SBC, TH350 w/3500 Stall, 12 Bolt, 4.56:1 Gears. Currently in progress...DSE Minitub Kit, DSE front suspension, DSE SFC's, 17" Budniks, Baer front and rear discs.
      http://www.cardomain.com/ride/2391864
      SoCal
      Quote Originally Posted by ItDoRun
      Personallly I like to over build the engine because I know damn well that I am always wanting to go faster. Once you see what the car will do on pump gas & low boost you will be amazed at what happens with race gas and high boost.
      I would get splayed main caps, steel crank, forged 8.0:1-8.5:1 pistons, & H-beams. As far as the heads are concerned there are way to many options to really pinpoint a specific brand(Everyone has an opinion). I would go with a 72 cc or higher chamber. Cam specs are more complicated but typically you are looking for something with very little overlap. I'd recommend you talking to any of the big manufacturers crane/comp/crower etc because they all have turbo specific cams off the shelf.
      What are you going to use for fuel management?
      '04 IS300 VVTi GTE swap GT35R etc (dead tranny - looking for LS swap)
      '63 Street Fighter Nova(Sold)
      '06 Magnum SRT8 KIA 10-25-13
      Feb 2006
      Southeast Louisiana
      fuel injection. I have a friend who is an EFI wiz, and he'll be helping me piee together the EFI system.
      Milwaukee WI.
      Youll have 15g in the motor besides the turbos.... A turbo LS1 all stock will make 700 hp all day long.....Stock!
      Did you consider going LS1??
      Twin Turbo Ls1 '71 Chevelle
      93 octane 1000 hp street car!!
      Feb 2006
      Southeast Louisiana
      15g??? I'm not trying to sound rude, but could you itemize what your proposing for a 15g motor?
      SoCal
      Good luck with the project!
      Los Altos CA
      15g might be a bit north but it will be very close if you dont intend on blowing it up, for all the money to get alum heads, fuel injection, and any bottom end strength you would be way better off with a gen 3, considering you can find a truck 6.0 with an auto bolted up for about 1/3 the price of a ls1 and they can take lots of boost!
      Aug 2001
      Wilton, CA. (Sacramento)
      Here's a list on an LS2 turbo build, cost was over $13K for the assembled long block. You still need all the accessories and oil pan, and obviously it could be done cheaper, but this was a good quality build.
      new LS2 block
      billet caps
      ARP main studs
      Callies 4" crank
      Mahle turbo pistons
      Howards rods
      ported oil pump
      MLS head gaskets
      Morel lifters
      custom roller cam
      lifter trays
      new rockers and hardware
      custom restricted pushrods
      heavy duty timing chain and gears, dampner
      ARP head studs
      ET Performance CNC 245 11 degree heads
      LS2 front cover and gaskets
      LS2 valley cover and gaskets
      LS2 rear cover and gaskets
      billet valve cover spacers
      fully machined, balanced, and assembled by Wheel to Wheel.
      Milwaukee WI.
      Here is a breakdown of all of the parts in my last motor I just sold. 427" sbc. It adds up FAST! This is a bullet proof combo, but you can see cost can add up fast for a real nice motor.
      MY 427 SBC
      BLOCK $2,000
      CRANK $1,200
      RODS $1,150
      PISTONS $880
      BEARINGS $170
      GASKETS $130
      RINGS $140
      MACHINING $900
      ASSEMBLY $600
      BALANCING $300
      OIL PAN $180
      TIMING CHAIN $150
      TIMING CHAIN COVER $15
      FLUIDAMPER $250
      ENGINE BOLTS $50
      HEAD STUDS $130
      DAMPER STUD $25
      ROLLER CAM $275
      CAM BUTTON $10
      LIFTERS $480
      PUSHRODS $140
      VALVES $260
      SPRINGS $250
      RETAINERS $120
      SPRING SEATS $10
      VALVE COVERS $200
      ALTERNATOR $260
      GEN 7 $1,450
      DISTRIBUTER $400
      CRANK TRIGGER $230
      HARNESS $50
      PULLEYS $60
      WATER PUMP $60
      STEERING PUMP $200
      INTAKE MANIFOLD $500
      INJECTORS $500
      THROTTLE BODY $800
      FUEL RAILS $125
      HEADS $1,800
      SHAFT ROCKERS $1,150
      HEADERS $400
      AIR CLEANER $110
      OIL PUMP $70
      OIL PUMP SHAFT $20
      ALT BRACKET $180
      PLUGS $20
      WIRES $80
      P/S BRACKET $30
      MOTOR PLATE $180
      VALVE LOCKS $35
      AN FITTINGS $240
      TOTAL $18,965
      Cumming, GA
      "Twin turbo", "reliable", and "cheap" do not belong in the same sentence
      Todd B.
      Vengeance Racing
      Formerly at:
      Kurt Urban Performance and Wheel to Wheel Powertrain
      Milwaukee WI.
      Quote Originally Posted by Reckless
      Turbos are the most reliable way to makle BIG power, It can also be done much cheaper and more reliable then the same hp N/A or nitrous motor, You might want to rethink that mis-informed statement.
      May 2000
      Quote Originally Posted by nitrorocket
      So to you, $15k is cheap. Since you just told the guy he'd have that much in the engine.
      Milwaukee WI.
      Quote Originally Posted by MarkM66
      Noooo, I said he would have $15K in a SBC that would handle big power. You can do an 800+ hp Twin turbo ls1 for under 13K if you do it yourself and only get the correct stuff you need. That is cheap for a turbo setup! Check out what local shops want fot a complete TT setup! You will faint!
      That is the main reason I switched to the LS1 is the low cost of them and the ability to handle more power with stock parts then a SBC.
      Do reasearch on what you like and start buying parts, before you know it you wil be ready to turn the key! You will LOVE turbos! If you stay SBC you wil need a 4 bolt splayed block forged crank, billet rods, and forged pistons. If you put some good flowing heads on there, you are looking at about 900-1000 hp at the crank at 14 psi! I would go with 60-1 or 60-1 HI-FI turbos with a .69 tang housing with either a B or E compressor cover. Both will get the job done.
      GOOD LUCK!
      Cumming, GA
      I want to see a 1500hp NA engine that is streetable
      Todd B.
      Vengeance Racing
      Formerly at:
      Milwaukee WI.
      There isn't such a thing as a 100% streetable N/A motor that could see any big miles or be practicle.
      1000 hp (give or take a little) seems to be the magic # for most turbo and supercharged motors that are 100% street driven. Much more power then that and you have to start using non streetable high wear parts like huge cams and monster valvesprings just to name a few.
      Cumming, GA
      OK, so show me a 1000hp NA engine that is streetable, or 800hp, or how many are even 700hp? Point is, you are talking about two different entities. We can build a twin turbo LSx setup that will make 1000hp on any day, but is it on pump gas? Probably not. People have to use a little common sense when asking for power levels for a street car. Anything over 550-600 rwhp is pretty much useless on street tires. Numbers beyond this are just for ego really. I can admit it
      Todd B.
      Vengeance Racing
      Formerly at:
      Milwaukee WI.
      What are you talking about?? I NEVER ONCE STATED THAT ABOUT AN N/A MOTOR.
      I am saying you CANNOT have a good high hp N/A street engine compared to F.I.
      Do you have what I am saying mixed up??? Reread what I have said, I basically said that to make an honest real high powered street engine you need forced induction, and the limit is rougly about 1000 hp. You keep bringing up that you cannot make a high hp N/A motor, and I agree!
      This guy wants to make about 14 psi on an engine with aftermarket heads. That will make 900-1000 hp at the crank depending on exact combo. I am trying to give him turbo advice.
      And for the record, I have an LS1 motor making roughly 1000hp on 93 octane. It is pretty easy now a day's with the good heads and turbo technology out there, There are Mustang guys making huge #'s on pumpgas(1000 RWHP!), Seems things have come a long way in a short few years!
      North Vancouver, British Columbia
      Im confused.
      Feb 2006
      Southeast Louisiana
      Actually I'm just looking for about 500-550 hp at the rear wheels. I'm not trying to build a beast here. Just something with considerable power, different, and fun to cruise and play around in. I guess with this in mind, would a 4 bolt block with forged internals and h-beam rods be sufficient for this kind of hp and 12-14 psi boost?
      Milwaukee WI.
      That power can be done with only 8 psi, so you dont need much of a motor buildup. Just a forged rod and forged piston with basic aftermarket heads. You will be able to do this fairly cheap, just know what you want to buy before you buy anything.
