    Results 1 to 9 of 9
      USA
      Power steering cooler
      I have been reading about the p/s cooler on David Pozzi's site. I'm confused about something. Which type of cooler is noisy and which type is more durable ? One is called a flat tube and the other is called a round tube. What's the difference? I think one design is like a small radiator or heater core with a flat bulkhead at each end. And the other is just round tubes with fins. Am I right ? I was going to use a small trans cooler in the p/s return line as a p/s cooler.
      Jeff Tate
      U.S.A.
      Eastern Virginia
      Where is David Pozzi's site?
      THanks
      Scot
      86 Monte SS
      Central CA USA
      I don't know if one is noisier than the other but the flat type is like a small radiator and according to Tom Lee, the flat type is more easily damaged by pump pulsations. We used a small trans cooler with round tubes. My wife ran the car at Streets Of Willow in 100 degree heat and the system stayed cool.
      There is a little pump noise on my wife's car when parking but it's not bad. I've read that most remote reservoir systems are noiser than stock systems.
      USA
      Thanks David ! Your knowledge and experience is priceless. Thanks for sharing. Your website is great. You always seem to give a realistic view of how to get performance results without unecessary expense or flashy " wow " parts.
      Jeff Tate
      U.S.A.
      USA
      I bought a transmission cooler to use as a power steering cooler.
      Will it hold up ? I know that power steering pressures are higher than transmission pressures so will the increase in pressure and/ or flow cause a deterioration or leak in the trans cooler ?
      Also , will trans cooler hose work to plumb the p/s cooler or should I use dedicated power steering cooler hose ?
      ( Obviously I'm putting on the return side )
      Jeff Tate
      U.S.A.
      Central CA USA
      Trans cooler hose will work.
      A trans cooler is good, it doesn't have to be a huge one, ours has four passes and is 3/4" thick.
      I'm not interested in overly flashy parts, just getting the job done. I guess it comes from my early years, - not being able to afford flashy parts.
      David
      USA
      Me too David. I want to drive this car a lot . I can't justify dumping huge quantities of money for parts that aren't 100 % necessary.
      There is someone here on the site that has a slogan at the bottom of there posts that says something about huge wheels and huge brakes not impressing them ,but quick lap times do.
      Jeff Tate
      U.S.A.
      I have one in my car came with my LS1 engine as in WS6 Trans Am. It is inline with the upper radiator hose.
      67 Pro-Touring Camaro
      ISMAIL
      Jul 2003
      Anaheim Hills, CA
      The guy who built my PS pump said I really won't need a cooler since he builds his to run cool from the start.
      I was going to run that and an oil cooler, I sill might run the oil cooler depending on how my temps end up running.
      I wonder where you could plumb in a guage to track PS fluid temps? I imagine you could use an oil or trans temp gauge.
      1968 Track Rat Camaro:
