Thread: Clutch Fork Spring
06-27-2006 #1
Clutch Fork Spring
How does the clutch fork spring and extension rod attach to the clutch fork and the block/frame? Does the rod go to the clutch fork or the spring? Also where does the block/frame end attach? I have a Gen VI 502 in the Nova.
Also how do you adjust the linkage to get the clutch to grab at a physically higher point on the pedal. Right now mine grabs right off the floor and I would like to bring the grab point closer to the top of the pedal stroke.
Justin
73 Nova, 502 ci, TKO600, Mosier Eng 12 bolt, 6 point roll cage, Wilwood rear discs, factory front discs, 250 HP nitrous, subframe connectors, Slide-a-link trac bars, 17" Boyd Coddington Smoothie II's, and Hotchkis TVS kit.
06-27-2006 #2Hey Justin,
I'm also interested in an answer to your linkage adjustment question. My clutch also engages right off the floor.
As far as the spring attachment locations.... One end attachesto a hole in the clutch fork near the pivot rod. The other end attaches to a small bracket on the driver's side frame mount (not motor mount). I didn't have that bracket so what I did was fab up a L-bracket that mounts to the rearmost frame mount bolt. The bracket has a small hole in the other end where the spring attaches.
I have a pic somewhere of how all that stuff goes together. I'll see if I can find it and upload.
06-27-2006 #3
