    Results 1 to 15 of 15
      new york city
      remove pilot bushing
      Hey,
      What is the easiest way to remove a pilot bushing from the crank with the engine in the car? Slide hammer?
      Any help would be appreciated.
      Jan 2002
      Crockett, Texas
      Well, without the tool, you could thread a 5/8 bolt into it, and it will bottom in the crank and pull it out.
      Don 67 Camaro RS/SS Texas
      Cape Cod Mass.
      we pack some grease in the hole and use a spare input shaft out of an old trans just tap it and keep adding grease , it may make alittle mess but does work we've done it may times
      NOW WHAT??? lol
      La La Land, CA
      If it is bronze you can cut it out with a chisel.
      Tyler
      Aug 2001
      Bonze ones are very easy to tap and then screw a bolt into.
      Jan 2000
      Thousand Oaks California
      I've had luck with Play-Doh and a very close fiiting pin and a hammer in the past. Bernoulli's Law works pretty well.
      Larry Callahan
      Delaware, OH
      With a bronze bushing, you can also use a hacksaw blade and manually cut all the way through one side. The bushing will then compress and pop right out. A SawzAll works as well, just be careful not to saw in to the crank.
      Welland, Canada
      Another vote here for the tap and bolt method, works like a charm with no mess.
      Actually what I did was use the tap itself to draw the bushing out.
      Dean
      69 Camaro 355-3.73 Moser Truetrac-TKO600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's
      ST U/LCA's-GW Del-a-lum's-Lee p/s
      new york city
      Does the tap and pull method work with a roller bearing?
      Thanks for all the suggestions.
      Aug 2005
      Hamilton, NJ
      Man, I pulled the bronze one out of my crank by filling it with grease & tapping a dowel into it (actually, the handle of a small hammer I own fit nice & snug – perfect). Popped right out.
      I don’t know about a roller one. But I think the local Advance Auto or Auto Zone might have a puller on the shelf as part of their borrow-a-tool program.
      Scott from NJ.
      Vent Windows Forever! ...
      Nov 2004
      Sweden
      Country Flag: Sweden
      Pack some grease in the hole worked for Me.
      I used a bolt ,with silver tape on the thread ,to make it as tight as possible.
      Then tap the head of the bolt with a hammer, and the bearing will come out undamaged .
      OSDMIKE
      Berlin Heights , Ohio
      I have actually used wet toilet paper instead of grease. Little less mess
      cleanups a breeze.
      I've use these tools with great success. Hard to beat for $20 delivered to your door.
      http://www.springertool.com/
      http://www.bc4x4.com/quick/2003/springertool/
      NYC
      your best bet is the good ol grease method.
      George
      `67 Buick GS 400 Hdtp,494ci Stage 2 BBB,5-speed TKO-600,"The Black Widow"
      Maryland
      Old timer showed me the wet toilet paper and a tight dowel method,works great,cheap too
