Results 1 to 11 of 11
Thread: 408 stroker vs 383 stroker?
06-24-2006 #1
I am at the point in my project (69 Camaro) where I am ready for my motor.
I have a Muncie 4 speed and a 373 rear. The car will be used 90% on the street. No vacume accessories and I want a real nice thump at idle.
I was planning on building my own 383 until I ran across T&L engines. http://cgi.ebay.com/ebaymotors/408-C...mZ300000903481
I never thought about a 408.
What are your opinions on a 408?
It looks like it is still a 350 block (4.030) but with a 4.00" stroke vs 3.75". Is that correct?
Steve
06-24-2006 #2
- Sep 2004
- Lancaster,CA
- 22
Well I'm not sure which engine you will like better but a 383 sbc is a 350 block with a 4.00'' crank out of a 400 sbc.This 408 is just a 400 that has been bored to rebuild it.The 400 does have a little bit different set up than a 350 as far as needing holes drilled in the heads for the steam passages on the block but its not a big deal.Just beware I purchased any engine on ebay once and it was junk even though the guy had a great rating and I talked to him before hand.
06-24-2006 #3
Banned
- Aug 2003
- Orlando, FL
- 8,745
The stroke on a 400SBC is 3.75 which makes a 383. I did not look to see how they are making 408, but if you are starting from scratch, a bigger bore 400 based block will kick the doo doo out of a smaller bore 350 block based motor. there is no substitute for the advantages of valve unshrouding that comes with the bigger bore size.
06-24-2006 #4
- Sep 2004
- Lancaster,CA
- 22
my bad
I apologize I guess I was given bad info on a 400 crank if thats the case than your right where are they getting 408 from.
06-25-2006 #5I build engine's and I dont like 383's.If you want a stroker I would build a 396,or go to the 400 style and build a 406 or go 427 or 434.
You can make any engine thump,it's all in the cam,I can make a 355 sound like a 427.
06-25-2006 #6
- Aug 2004
- Dunwoody, GA
- 4,983
