Results 1 to 17 of 17
Thread: car alarm idea...
10-25-2004 #1
car alarm idea...
Okay, I've been thinking about this for a while now and I'd like some input. I do not want an alarm with all the blinky-blinky, honk-honk, "stand back, protected by...." -you get the picture. I want an unassuming alarm. If someone is really wanting to steal your car, and if they know you have an alarm by you activating it, seeing a red light flashing, etc. they may have knowledge of how to dis-arm it. I know we've covered this before and alarms are only deterrants BUT-I'm thinking of a two-stage system and here's how it would work: First, you have to have a primary system of defense such as honking horns, flashing lights, etc. but how once a thief can get in, if he has knowledge of where to cut power to the alarm, he can get inside and dis-arm it. Now, I could be wrong but every alarm I've ever seen has a siren for the outside-but how about mounting the siren horn on the inside-say way up under the dash? Sure he may get in but damn, with a loud-@ss siren blaring off inside of a sealed cabin-how the hell could he even think let alone sort through wires looking for it. And, if he did somehow manage to shut it off, how about using an ignition cut-off from say a Caterpillar? They run about $40 and use a special key which dis-connects the negative cable from the battery. You could run it through the frame and up your tranny tunnel and into your console. So, the next question is how to use the dis-connect switch in conjunction with a relay that can be triggered from multiple sources like the dome light, ignition lead to the coil, dash lights, etc. to turn on the siren from the inside too? I want their damn ears to bleed form the inside out with this design. What do you all think? Suggestions for a siren? How about a tornado siren?
That would surely make them fall out of the car holding their ears!!! -Jabin
10-25-2004 #2I like it. Ive always had the same issue with anyone whose gonna try and steal our cars is more then likely to know how these things work, so a secondary cut off switch sounds good even if u cant wire them togther. Have them mess with the box only to find out they still have no power!
David:3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
10-25-2004 #3I had my bird broken into once. after that i kept a pitbull inside, but i think the dog did more damage in the end
Kept people away though
-David
10-25-2004 #4
