      Wisconsin
      TKO Neutral Safety switch
      TWO QUESTIONS:
      #1 Wondering if I can wire the existing wires that ran to my automatic floor shifter (B&M) to the neutral safety switch on the TKO600 and if it will function properly then. I have an aftermarket Ron Francis Express wiring harness. Or do I have to run some kind of clutch pedal switch? I like the fact that on newer cars you have to have the pedal all of the way pushed down. Was thinking that if I just ran the wires direct to the TKO then it would only start in neutral! And I don't wanna have to put it in neutral everytime I want to start it
      #2 When wiring Autometers electric speedo, would the 12 volt wire run to the positive sensor "B" and the other pin on the forward side of the plug (the negative pin) be wired to the signal wire running from the speedo? Or vice versa?
      Justin
      73 Nova, 502 ci, TKO600, Mosier Eng 12 bolt, 6 point roll cage, Wilwood rear discs, factory front discs, 250 HP nitrous, subframe connectors, Slide-a-link trac bars, 17" Boyd Coddington Smoothie II's, and Hotchkis TVS kit.
      Encinitas, CA
      Here is a link to some helpful info for you:
      http://www.chevelles.com/techref/ftecref4.html.
      Jeff Mortenson
