Thread: 10 mpg Speed demon
10 mpg Speed demon
hi
i run on my elcamino with a 750 VE speed demon.
the car runs great, dyno 330rwhp.
when i read in many forums about consumption, i donīt understand my engine. 10 miles per gallon, i think this is heavy.
the barry grant speed demon have the stock setup:
MODEL #
750V
PART #
1402010VE
VENTURI SIZE:
1.400
IDLE AIR BLEEDS:.070
H.S. AIR BLEEDS:
.039
BOOSTER TYPE:
DOWN LEG
BOOSTER LEG:
.160
SQUIRTER SIZE:
31 STD.
BUTTERFLY SIZE:
1-11/16
AIR HOLE SIZE:
NONE
PUMP CAM #
# 330
PUMP CAM COLOR:
PINK
VACUUM SEC. SPRING:N/AYELLOWPLAINPLAINPLAINMETERING BLOCK # P.
A-12400
METERING BLOCK # S.
A-12402
SIPHON BREAK:
.028
E-HOLE POS. #1
.031
E-HOLE POS. #2
N/A
E-HOLE POS. #3
.031
E-HOLE POS. #4
N/A
E-HOLE POS. #5
.031
P.V.C.R. SIZE:
.059
TRANSFER SLOT RES:
OPEN
IDLE FEED RESTRICTOR
.033
MAIN JETS PRI:
# 76
MAIN JETS SEC:
# 83
POWER VALVE PRI:
6.5 STD.
POWER VALVE SEC:
N/A
LINKAGE TYPE:
VACUUM
N&S SIZE/TYPE:
.110-VITON
ACC. PUMP DIA. SIZE
30CC
any idea what i can change or set up ?greets
Klaus
