Thread: Calling the Cam Guru's.... Help
06-08-2006 #1
- Dec 2004
- Crestview FL
- 276
I am in the market for a new cam and possibly an intake change. I have called all the major cam manufactures and of the 4 I got 4 different suggestions.
go figure! Anyway I thought I would run them by you and see what kind of input I get here. Also if anyone knows a true expert in the subject and has a contact number for this person I would love to make the call and talk with them before I make the swap. ok here is what I have now. 383ci stroker with Comp magnum 286 adv. 236 236 @ .50 with a .560 in and .560 ex. The cam is the retro-fit hydro roller and I have the rev-kit from AFR. The dyno showed 337hp to the wheels @ 5800 and a torque curve that was not measured below 4500 but read 335 @ about 4500. (there was a problem with the torque reading on the dyno) The comp is 10.5-1 with 195 AFR heads and an Airgap intake. The AFR's were ported and flowed 278in and 212 ex. The stall is rated at 3000 and I can foot brakes it to 3200 and it will flash to 3500. I am not worried about vaccume to much as I have no power breaks to worry about. The only vaccume accessory I have is the RS headlight doors.
When I make the swap I was thinking of switching the springs out for the new bee-hives and running a .600ish lift
Ok here is what was suggested to me...
Mark -
Lunati Suggestions
601-13 243/251 560/565 110 LSA lunatic
7530 team g intake
Comp Cams recommends
292 300 242 248 Advertised .548 .543 110 lsa 2800-6500
66 over lap pt number 12-000-8 cs 3018-3039hr 110+4 $309.00
Ultadyne
296 302 242 248 108 lsa .530 .530
531-10 kirk $310.00
Crane Cams
240 248 .558 pn. 11hr00032 $383
106 lsa
What does everyone here think???
__________________
06-08-2006 #2I've had really good luck with Comp over the years, and I have a buddy with a tuning shop for late model iron that uses them almost exclusively and they are making some sick power. I like the duration specs of the one you list, but I would hate to give up lift and only pick up 6 degrees of duration. That motor should be making a bit more power anyway with those heads, unless it is restricted by the intake or exhaust systems. I would leave the cam alone for now and work on optimizing the rest of the system. If you really want to wake the motor up, switch to a solid roller cam with ~250 degrees of duration and around .6-.620 lift.
I had a motor like that for awhile. 383 w/ 6" rods. Cam was a comp with 251/255 or so and lift was .620/.600 - used 1.5's on the exh and 1.6 on the intakes. Heads were also AFR's flowed a bit more, like 287/228. CR was just under 11:1. Vr. Junior manifold - ported to match the heads, aprox a 1206 size. And BG 830cfm double pumper. 1 3/4" headers, good exhaust. Made ~530hp and propelled a 3900lb car to 11's at 116-118mph in the 1/4mi. Power band was 3500-7000rpm.
If you want the motor to really rip, go solid roller. IMHO, once you get above 240deg duration you are better off with a solid cam anyway. They give you better idle and low speed characteristics than a hyd of similar size, and you get much faster ramps which means more lift, more power under the curve etc.
Anway, with the cam you have and those heads, assuming the intake and exhaust system are up to task you should see close to 360rwhp thru an AT w/ loose converter. First step is to find the missing 25-30hp. Then figure out if a cam change is in order.
good luck!!
06-09-2006 #3
Starting The Transformation
- Nov 2005
- 130
Shoot me a e-mail or PM
Originally Posted by 69CamaroRacer
First DITCH THE AFR REV KIT!
Second what is the LSA of the shaft you have now? Is that lift with 1.5 rockers?
What kind of chassis dyno did you test this on?
Why didn't you test the motor below 4500rpm?
Good idea.
BretBauer Racing Engines
Specializing in late model GM motors
1964 GTO (work in progress for 13 years)
600 HP 365 cube SBC
C5 Front Suspension
Satchel Link Rear
T56
Not gettin done anytime soon
2000 Camaro SS SCCA FS Car
Koni Adjustables
35mm Front Bar
DOT Race tires....
06-09-2006 #4I'll post my own suggestions later this evening when I have more time. For now I would suggest calling Isky and talking to Ron
www.iskycams.com
VERY smart guy.1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
Just call me Brett
