Thread: Shocks or Travel Limiters?
06-08-2006 #1
I'm finally getting around to finishing some things on the rear suspension on my 85 Monte Carlo SS. It's been lowered 3" and running a shorter spring. Now u know that with standard length shocks the spring can fall out of its pocket. Does anybody know where to get bolt in lowered shocks (beside BellTech) to keep the axle from dropping to far or a quality suspension travel limiter that doesn't need welded on. The other side is factory shocks just bottom out on compression and need one with a shorter compressed length. I have set my mind on Bilsteins or maybe VariSshock, just depends on what the budget allows.
TIA for your reply or E-Mail me atdocument.write(''+'85ssmonte'+'@'+'comcast.net'+'') [email protected]
06-12-2006 #2
Starting The Transformation
- Oct 2004
- Indiana
- 221
First measure up the car for your ride height ( where the car sits static ), compressed height ( to the bump stops ) and extended height ( can vary, but atleast try to give yourself 2" of extension stroke from ride height ) Then you can usually match them up with an existing shock absorber.
06-12-2006 #3BTDT. Trying to keep factory hookups and had no luck. Seems not too many cars used shocks like the 80s G-Bodies. I went through the entire spec catalog and found a VW that I could make work. Problem, valving for 2 different kinds of cars. I may have the solution, just not confirmed, yet. Thanks.
