Thread: LT1 or miniRam Gen1 ?
06-07-2006 #1
I am picking up an early Camaro - most of the work is already done, suspension is dialed, paint is done, interior is 90% good, main items I need to address are manual trans conversion and adding more power. The car currently has a 12K mile LT1 / 4LE60 combo. Motor is stock except for the LT4 HOT cam. Makes ~375hp at the moment. My goal is 450hp.
Options on the power side include adding cam and heads to the existing LT1 stock shortblock, or dropping in a complete 355 Gen1 motor w/ miniRam that I had built for a C4 road race car project that I decided to sell before finishing. I've done the math and it actually works out to be cheaper to use my 355 motor once factoring in selling off parts from that vs. selling off the complete LT1 / 4LE60 combo w/ wiring harness and ECM. Both motors could easily make my 450hp goal and be perfectly streetable. But with the Gen1 motor I would have some nice things, since I already have them.
Gen1 motor uses Dart Pro1 200cc heads. They flow close to the LT1 ported heads I would use if I stick with the LT1 motor. Cam on the Gen1 motor is a solid flat-tappet, probably would go down 1 cam size from my race cam to a 236/242 with .533/.550 lift. I would run a similar sized hyd roller in the LT1. Solid cam might be slightly better for MAP signal, but downside is quarterly or at least couple time per year valve adjustments. That doesn't bother me in the least, however.
A few advantages I can see to using the Gen1 motor:
- all forged bottom end, strong manley rods, 4 bolt main block, race prepped machine work and tolerances
- no opti to crap out on me
- more options down the road for future motor combos
- parts are generally more available and cheaper for Gen1 stuff
- already have a nice billet AL flywheel
- canton RR pan
I can't really come up with an advantage to the LT1 other than it would be easier since it is already in the car. Gen1 motor means wiring in a new TPI based engine harness and I would use a 730 ECM.
Sorry if I am skewing this towards the Gen1 motor. Can anyone come up with a reason to stick with the LT1 that I haven't considered?
