05-23-2006 #1
New to Pro-Touring
- Sep 2004
- 21
T-5 install Help...I know..should get the t-56...
I got a t-5 with 50k miles on it for free from a buddy. I drive my camaro to work 60 miles every day with a 350/TH350 combo. needless to say I am going broke filling the thing up with gas. I am only installing the t-5 untill I can save the 3500 for the built T-56. I have everything for the install except for the clutch set up and flywheel. My question is which flywheel do I use...the 68 or 90 that the trans came from. I have to use the 26 spline clutch disk so that it fits the trans shaft. Will a 90 camaro pressure plate fit a 68 flywheel or is there another I can use... any help is tremendously appretiated. Thanks
Oh, my motor is externally ballanced...
05-25-2006 #2
- Dec 2004
- North Jersey
- 983
What bellhousing/linkage are you using?
Either way, you'll need the flywheel to fit the motor; the '90 had a 1-piece rear main seal and the bolt pattern is different compared to the early (pre-'85) motors. If you are using the late-model bellhousing, get a flywheel for an '85 IROC; if you're using an early bellhousing, you'll have to fabricate a trans mount because it'll be tilted on a 17* angle.Steve Ragusa - North Jersey
2006 Infiniti G35x
06-04-2006 #3
New to Pro-Touring
- Sep 2004
- 21
I am using the t-5 stock bellhousing that is tilted at the angle with the hydraulic clutch. So I should use an '85 flywheel? That will fit to the '89 pressure plate? I'll go to my local parts store and see what fits...thanks
06-04-2006 #4
