Thread: Fuel filler misaligned
05-31-2006 #1
I have a 67 Camaro and a narrowed stainless fuel tank from DS&E, I noticed recently a BAD leak when filling up. After inspecting through the access area behine the license plate I discovered that the rubber hose that attaches the filler tube to the extension tube on the tank had to make a severe bend forward to attach to the tank and was being pulled off of the tank extension causing the leak. I don't think the tank can be moved back any further to align the tank extension with the filler neck, anyone else run into this problem, any ideas on a solution? I was thinking maybe a more flexible connecting hose, but not sure what to use that will withstand the fuel... Any ideas would be helpful.
-George
