- Sep 2004
- 71
Hotchkis Rear Spring Height Problem
I have a 67 Camaro with Hotchkis front and rear. The front came out great however the rear is too high - about 4" gap between fenderwell and top of tires (275/40 -17). Is anybody else having any issues with the springs? I tightened with weight of car on ground and we have now driven it a few days with no change. The car has never been hit so that isnt causing the problem. Some other pics of 67/68 Camaros and measurements from center of wheel to center of fender lip would be very helpful.
05-29-2006 #2Well i installed the same kit on my 69 camaro and the only problem i ran into was that i had to shorten the driveshaft by about an 1" because the springs moved the rear end forward slightly. As for you height problem im not sure whats up with that, cause i have 255/60/15 and they tuck nicely in the rear, but ill take some pics and measurements to see if they can help you.
1969 Chevy Camaro 350-8th cylinder gone =[-
2005 Dodge Viper SRT-10 505/ 510hp
05-29-2006 #3
