    Results 21 to 40 of 48
    1. #21
      Aug 2003
      For you guy's wanting Classic Air, over at GP Store there is a wanted Group Purchase about to go to active GP. If you are interested, come over and let us know.
      http://gpsuperstore.com/forum/showthread.php?t=142
    2. #22
      Macon, Ga.
      A couple things here. The A/C on the goat is a mixture of parts. I retained the Factory dash unit, and everything on the firewall to keep the large evaporater. Then used a LS1 style compressor and Griffen custom condenser. Today is the first day I have needed the A/C here but it worked like a champ. However, it is a 65 convert, so many air leaks, and a black top will probably tax it in the summer.
      Just something to try, I have never used the vintage air stuff but found this problem on many cars I have owned. So maybe this could be an issue. Be sure that water is not flowing thru the heater core. Just plug it temporarily and see if that helps. If hot water is in the heater core, the system is working against itself. This may be a long shot, but try it, cheap and easy to do and may help.
      Bill
      Trailers are for BOATS!
    3. #23
      Nov 2004
      Napa and other parts houses sell a shutoff valve that fits inline (heater hose) on the inlet side of the heater core. What Bill has stated above does make a considerable difference in the summer time heat.
      Gerald
    4. #24
      SoCal
      Doesn't the electronic shut-off valve (at least there was one in the VA kit that I used) keep hot water from entering the evaporator unless the heat is turned on?
    5. #25
      San Antonio, TX
      Good point , Bill.
      Tom,
      It is common for installers to have the heater valve installed backwards or in the wrong hose, which will allow it to leak past the seat. Also, though not as common, I have seen dirty coolant systems jam or damage the valve with rust and other debris.
      If you touch the fittings coming out of the unit when the valve is closed, they should both be the same temp and relatively cool. If they are both hot, you have a bad leak past the valve. If one is cooler than the other, you have a slow leak through the valve.
      If the duct temp warms up when you run the engine rpm up, you have a leaking valve.
      When the car cools well while parked, then warms up while cruising or on the highway, its probably leaky door seals or holes in the firewall.
      Ryan
    6. #26
      San Antonio, TX
      The gen 4 systems are currently available for '55-57 Chev. cars, and '68-76 Corvette. Many other applications are coming soon.
    7. #27
      north central Iowa
      Quote Originally Posted by KUL FIR CHICK N
      can you give me the dimensions on the gen4? I might have enough room under the dash of my impala for it.
      Making brackets doesnt matter to me because I have to make them anyway for my 70 impala.
      Also what is the price diff. between the gen 2 supercooler and the gen 4?
    8. #28
      Aug 2003
      Quote Originally Posted by justanova
      I have a killer deal on a supercooler Jagarang ordered for his Firebird, and it won't fit. I can set you up with everything else also.
      Frank
    9. #29
      north central Iowa
      Quote Originally Posted by ProdigyCustoms
      Frank
      you have a pm
    10. #30
      Jun 2005
      Pinetop, Az
      Interesting info from Bill and the chicken fried guy from vintage. I read it today, and it seems to confirm what we discovered yesterday.
      My car has ALOT of dynamat. Holes in firewall are all plugged up. Windows tinted much darker than I would really like. When Idling yesterday in the shop in Phx, the air was somewhat cool. They had just worked over an issue with the lack of volume through the passenger side vents. I went out to take it for a drive and noticed when I got on it, the air coming out the vents warmed up considerably. The shop has determined that the electric valve is stuck part way open, thus running warm water partially through which then won't let the unit either heat or cool properly.
      This seems to have been the culprit for the last 20 months? I guess it adds to my frustration on this vintage unit. I am now on control panel #3, which has come apart twice. The controls for the 69 camaro are just plain idiotic to figure out as you have to play with them to see which way to set them for hot/cold as they are not clear by looking at them. Trying to deal directly with vintage air is an excersize in frustration in customer support and getting parts!!! And when you finally figure out what the problem is, guess what--YOU'RE OUT OF FRIGGEN WARRANTY, so you get to spend some more $ to make the unit right like it should have been to start with.
      Gripes my fricken bunny...and chicken!!!!!!!!!!!!!!!!!!!!!!!!!!
    11. #31
      Vail, Arizona
      I feel your pain man. I have had some less than stellar customer service too. One guy was outright mean! But, I have learned to expect it in todys society. (Whole other issue there!) Hopefully now that you figured out the culprit it will work perfectly for you. It is definitely hot here now huh? Ouch...I long for winter!
    12. #32
      Macon, Ga.
      Bad news is you will have to buy a part or two. The great news is, once you correct the problem, the unit you have now should do the job, and you are not looking at replacing the whole thing. Personally I would rather replace the bad part, at my expense than to have to incorporate a new, different style unit into a together car, even if they gave me the newer unit. Just me.
      Bill
    13. #33
      Jun 2005
      Pinetop, Az
      Well there is a little bit of silver lining.
      First, although located in Az, and my shop that works on it is in the Phx area, I live in ne Az (Pinetop) that is typically 75-85 in the summer, instead of 105-115. I do as little driving in Phx in the summer as possible.
      Second, yes it is better to have to just replace the part (I've already had to replce the unit under the dash once), so that will hopefully simplify it, but doggone it, would'nt a really good company send you the part at no charge? And of course in a perfect world, they'd cover the labor charge to boot.
      Just dreamin I guess???????????????
    14. #34
      Macon, Ga.
      Quote Originally Posted by Dan Sherwood
      Not in my experience. Warrenty time is just that, no one can warrent a part forever. There is always the arguement of when the part went bad, how old is the part, etc. In a perfect world, the part would never go bad. I think if I were you, now that you have found the problem, take this up with them directly or with whomever you bought it from. Who knows, since honey goes further than vinegar, explaining the whole story to someone might at least get you a break on the part. That works for me anyway, most the time.
      Bill
    15. #35
      Hawaii-Las Vegas
      I have the sure fit Vintage Air kit in my 68'. It doesn't blow as cold as I would like, but does okay. Seems to blow better through the side vents and less through the middle ones??? Talked to my friend who has a system in his 57' Belair with LS1/6spd etc. He is not real happy with the systems performance either. But who knows, it gets really hot here in Hawaii? I am also thinking about changing out the control panel (currently hooked in to the factory controls).
      1963 Nova SS
    16. #36
      Jun 2005
      Pinetop, Az
      Bill-I agree that sugar will catch mre flies than mustard. Did not seem to matter with vintage, neither flavor seemed to do much. I would end up calling dse where i purchased the unit, and my guy there seemed to have better luck than I some of the time in getting something out of them. Stll very frustrating.
      My center vents don't have much volume out of them either, and until last week the pasenger side vent was'nt that great.
      At this point, the unit would probably cool ok up here in 75-85 degrees, but in Phx at 115, I think not.
    17. #37
      Chandler, AZ
      oops!
    18. #38
      Chandler, AZ
      ***At this point, the unit would probably cool ok up here in 75-85 degrees, but in Phx at 115, I think not.***
      Man sounds like I might need to get away from this heat or only drive my car during the winter months. How good does your heater work? I know the winters are much cooler in Pinetop than here in the Valley of the Sun.
    19. #39
      Jun 2005
      Pinetop, Az
      Ok guys- I wanted to give an update on my a/c.
      First off, let me give props where props are due. Mr. Ryan Zwicker from Vintage Air has been trying to contact me for awhile and we finally spoke today as I arrived at the shop working on the car in the Phx area.
      New electronic valve in place, and seems to work much better. It only got in the low 90's while I was there (very unusual for Phx this time of year) but it cooled the car the best it ever has. I have my doubts that anything over 100 degrees will work as well as I would like, but a definite improvment!
      I will have the car back down there next week, and we will see what progress we've made when it's well over 100 degrees.
    20. #40
      Macon, Ga.
      Sounds like good news to me Dan.
      100*, sounds like you need a new zip code not new a/c......lol
      Trouble with any a/c in an older car, other variables play into the mix. Most older cars do not have the proper insulation, are not as airtight, and just were never meant to be a creature friendly as we have grown to expect these days. If you can change the inside temp by 30* in the hot summer, that is pretty good for any a/c. Now, if you start out with 110* that is still 80*, but much better anyway. I am glad to hear Vintage Air went the extra mile to make you happy. I am also glad you gave us the update, complimenting them.
      Bill
