    Results 1 to 13 of 13
      Jul 2004
      Braselton, Ga.
      Need help with new avatar..
      Can somebody help me change my avatar to this:
      Your pictures is probably too big to be loaded onto the site as an avatar. Go find a site/program called "irfanview". With this program you can resize pictures/images. If you resize your picture to 640x1280 it should work fine as an avatar.
      Mike
      www.musclecardeals.com
      Albuquerque, New Mexico
      Looks like you kinda got it... this might work a little better though.
      Bump, don't know if ol' boy saw it.
      Jul 2004
      Braselton, Ga.
      Jul 2004
      Braselton, Ga.
      O.K. I am completely stupid!!!! I can't figure out how to get the image from IMAGE SHACK to down load. All I get is invalid file.
      Can someone explain this in "STUPID PEOPLE TERMS"!!!!!
      Jul 2002
      Mesquite, TX
      Imageshack should be providing some links after you upload your image. Can you post those up here?
      Jul 2004
      Braselton, Ga.
      does this help
      I selected all when I right clicked and this is all I get.
      Jul 2002
      Mesquite, TX
      Use
      http://img66.imageshack.us/img66/322...03077el5ea.jpg
      as the path to your avatar. (since it likely has dots in place of some of the text, right-click it and choose Copy Shortcut)
      Now if only I'd remembered where I had my old avatar stashed...
      Jul 2004
      Braselton, Ga.
      O.K. I have triedto put it in both spots, I can't get it to work. The picture I have is fine but it is B&W
      Jul 2002
      Mesquite, TX
      I was able to set your avatar for you.
      Jul 2004
      Braselton, Ga.
      Thanks Derek. Could you explain to me how you done it. I am not good on computers.
      Thanks a great deal!!!
      Jul 2002
      Mesquite, TX
      I used the moderator control panel, which doesn't help you much at all.
      When I was trying to do it the normal way, I went to the User CP, chose Edit Avatar, and entered the URL above in the Avatar URL box. Make sure that you have the actual URL and not the chopped up one the way that vBulletin shortens it (right-click the shortened version and choose "Copy Shortcut").
      Once you hit Save Changes, the new avatar should be in place.
