      Houston, TX
      LS2 engine with a LS1 computer
      Hello,
      I trying to start my car for the first time and it just spins and spins. I have a LS2 block and sensors with a LS1 computer and harness. Street and performance made the harness and were aware of the LS2 block.
      If I remember correctly, someone said I made have to swap the wire on the crank or cam sensor? I can't remember? Does this sound familiar to anyone? Cam sensor is the one on the front of the motor and the crank sensor is the one behind the starter, correct?
      Also, what does the "Clutch Anticipate” do? Should I ground this wire if I do not have a clutch switch?
      Phillip
      Houston, TX
      Never mind. It started.
      May 2006
      you can get a clutch switch at advance auto parts. but ive got some laying around if you still need one. just let me know.
