      Feb 2006
      Columbus, GA
      Second Gen rear seats.
      Can anyone tell me if the rear seats from a 4th gen will fit in a second gen?
      1970 SS Camaro, 502 RamJet, TKO600 Tremec, 3.91 Moser 12 bolt/Detroit Tru-Trac, C5/Z06 Brakes.
      the bottom part should pop in, but ive heard the top is too narrow. this is just what ive heard though sorry
      I am in the middle of doing this at the moment.
      The bottom parts are the same size, but the mounts are different. Instead of the spring/hook of the 2nd gens, there is only a bolt at the front center. At the moment I dont know if I can bolt straight into the floor, or if I need to make a bracket.
      The back part is narrower, by a good 8 inches or so. There is also a fair gap beteen the bottom of the upper and the trans tunnel. I managed to get all the fittings and brackets out of the donor car as a start point. The hinged sections (bottom corners) required widening about 2 inches each side, but the top posts/hook bit are pretty much OK width wise, but will need massaging to match the inner wheel well.
      One in, I expect that the inner lower trim panel will need cutting to fit around the new brackets, and I will have to make some form of 'dressing' to cover the new brackets and the gap.
      On the positive side, the lines on the upper and lower sections do line up OK.
