Results 1 to 10 of 10
Thread: Shopping list!
05-09-2006 #1
New to Pro-Touring
- Apr 2006
- vancouver, BC
- 50
Shopping list!
I think ive got everything sorted out!
Front suspension:
BMR upper and lower control arms: 739$ ( + $40 for upper balljoints i think)
QA1 Coilovers: 649$
AFX Spindles: 625$
Touring classics kit for above spindles: 650$
Also looking at front camaro steering box, not sure about that yet.. might also throw in some new tie rod ends, already have a 1 1/8 swaybar
REAR SUSPENSION
GW Leafs 325$
Rear del-a-lum shackles 192$
shocks ( not sure if going adjustable or not yet ) 100-200$ depending
touring classic rear kit $750
subframe connectors ~200$ ( might make my own at work )
AND that's about it :/
Lets not forget the 17" rims ill be buying to fit my new suspension
Centerline crusing custom Venturas ( how fitting for my car
$270 a piece ( unless someone has a hookup with centerline hah )
General UHP tires ( $79 a piece at tire rack )
AND NO I DONT WANT TO ADD ALL THESE PRICES UP!!
any comments or suggestions?
73' pontiac ventura.
383 powered, stock chassis
12.45@112
05-09-2006 #2
New to Pro-Touring
- Apr 2006
- vancouver, BC
- 50
oops i added it all up and came in around $5000 :( guess it could be worse!
12.45@112
05-09-2006 #3Looks good, but you never really mentioned what goals were for the car. Is it a driver, will it see track time etc?
As for your list you may want to consider going with GW control arms since you are using other GW pieces. This way you know the pieces were designed to work together. I would also go with the matching QA1s for the rear if your using their coilovers up fronr for the same reason. Good luck...
05-09-2006 #4
New to Pro-Touring
- Apr 2006
- vancouver, BC
- 50
im using the BMR arms as they dont change the stock geometery as instructed by AFX when using the taller spindles. he says the spindles with stock control arms will give better results
Coil overs for the back is perhaps a bit excessive as im running a leaf setup..
This car is a street only / drag once in a while ( dont have any further goals as per drag racing, already know how fast it COULD be with a drag setup ) It'd be nice to try a road course.. but i only have an auto with a high stall.. so i dont know how my tranny would really like all the shifting :/73' pontiac ventura.
12.45@112
05-09-2006 #5
- Apr 2001
- La La Land, CA
- 2,241
